Difference between Doogee X5 and Doogee X5 Pro
Home Forums Android Hardware Where to Buy 1949deal Difference between Doogee X5 and Doogee X5 Pro
This topic contains 0 replies, has 1 voice, and was last updated by  smartphone mania 1 year, 3 months ago.
  • #9444
    smartphone mania
    Obviously, Doogee X5 and Doogee X5 Pro are the same brand of Doogee and as to their differences, let’s read following.
    First of all, it is the price, they all are at a very affordable price, Doogee X5 is $59.89 while Doogee X5 Pro is $84.59. So how to pick up one from these two smart phones, it is up to your needs.
    Let’s summarizr the similarities first.
    Yeah, they both have 5.0 Inch HD Screen with a solution of 1080×720 pixel, 16 million display, IPS technology and multi-touch.
    Memory
    If you don’t need a smart phone for gaming or other entertaining app, you can choose Doogee X5 because it just has 1GB RAM and 8GB ROM. Instead, if you want a large storage, then i will recommend you to buy the Doogee X5 Pro, which has 2GB RAM and 16GB ROM. But don’t worry, if you want a bigger storage, their internal storage both can be up to 32GB.
    Chipset
    Doogee X5 Pro is Obviously an upgraded version of the original Doogee X5, which only means that you will get to see slightly improved hardware. The chipset present underneath the hood is an MT6735, which is running four Cortex-A53 cores at a speed of 1.0GHz, while X5 is the MTK6580 [/b]Quad Core processor. The operating systems of them are the same – Android 5.1.
    General Design
    In general design, Doogee X5 has a plastic body with just lock/unlock button and volume rocker in its right side and nothing in its left. Coming to design of Doogee X5 Pro, the handset looks terrific from the front and back, despite the fact that it features a plastic encasing surrounding its 5 inch screen. Doogee has incorporated a microUSB charging port at the top of the smartphone, making it easier for users to charge their handsets while using it in unison.
    Camera
    Doogee X5 offers a 5 megapixel rear camera and a 2 megapixel front camera, doesn’t sounds too good on paper, but for that price tier (almost free) you get awesome good results. As to the Doogee X5 Pro, it has an 8 megapixel rear camera and a 5 megapixel front camera.
    Connectivity
    Doogee X5
    2G: GSM 850/900/1800/1900MHz
    3G:WCDMA 850/1900/2100MHz
    Doogee X5 Pro
    2G:GSM 850/900/1800/1900MHz
    4G:FDD-LTE800/1800/2100/2600
    Other features
    Doogee X5 pro supports 4G LTE, OTG, GPS, WIFI, Bluetooth 4.0, Multilanguage, etc.
    The Doogee X5 supports 3G WCDMA, OTG, OTA, A-GPS, WIFI, Bluetooth 4.0, Multilanguage, etc. Also offers NFC (Near Field Communications), which enables devices transfer information into your cell phone.
    Battery
    Doogee X5 and Doogee X5 Pro both comes with 2400 mAh battery that does great work along with the processor, consuming low energy in stand-by mode.
    Hands on DOOGEE X5 specs, antutu, camera, game, review on Youtube.
    [video=youtube]https://www.youtube.com/watch?v=SFMdMo6wnv4[/video]
    If you still hesitate to pick up one between them you can click follows to check the details.
    Doogee X 5
    Doogee X 5 Pro
