Monday, January 16, 2017
Blackview BV2000s Unboxing and First Impressions
Home Forums Android Hardware News on Android Hardware Blackview BV2000s Unboxing and First Impressions
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 12 months ago.
  • #10098
    We have recently reviewed the Blackview BV2000 and right now we have a slightly upgraded model. Find out more in our first impressions article.
    Thanks to the Blackview Official for sending Blackview BV2000s for a review.
    Blackview BV2000s: Unboxing
    img_6720 img_6739
    The contents of the packaging include only the USB charging plug and the cable.
    Blackview BV2000s: DESIGN and FIRST IMPRESSIONS
    img_6735 img_6736
    When it comes to the design, nothing has really changed in comparison to the BV2000 model. The phone is made of matt plastic and it feels comfortably in the hand due to rounded corners.
    img_6732
    The device has a 5″ display, which is okay to look at but it only has a 720p resolution. It is definitely not the sharpest out there but it is quite good considering a low price of the phone.
    On the top we have a 2MP camera, LED light and some other usual stuff. On the bottom there are 3 non-backlit capacitive buttons.
    img_6728 img_6726
    The back is made of matt plastic and thus the fingerprints are not that visible.
    As far as optics, we have an 8MP snapper and a dual LED flash.
    img_6730 img_6731
    Under the hood you can find a usual combo on China phones: two SIM card slots and the microSD card slot.
    img_6723
    The buttons are located on the right and they are made of plastic. I can’t say they are of a bad quality but they feel a bit mushy.
    img_6724
    The headset jack and the micro USB port are on the top.
    img_6734
    Overall, the Blackview BV2000s is well made cheap device. It does not look or feel premium but it does not look very cheap either. Matt plastic finish and rounded corners definitely help with the grip. Also, 5″ display makes this phone compact and manageable with one hand.
    The specs of this phone do not impress but the Blackview BV2000s is all about budget. So far the phone looks and feels nice for a $68 device but we have to use it for some time. Stay tuned for a full review.
