[Active deal] Cubot H1 – Unboxing video
Home Forums Android Hardware Where to Buy 1949deal [Active deal] Cubot H1 – Unboxing video
This topic contains 0 replies, has 1 voice, and was last updated by  smartphone mania 1 year, 2 months ago.
  • #9464
    smartphone mania
    Most of people use their phone for just calling, listening to music, clicking pictures, viewing videos, and surfing the internet. A device equipped with long lasting batteries can give users great freedom to operate the phone for a long time without having to worry about charge running out. Therefore, i will recommend a smartphone with 5200mAh battery to you, that’s Cubot H1.
    Cubot H1 MT6735P Quad Core 1.0GHz Android 5.1 Smartphone 2GB Ram 16GB Rom 5.5 Inch HD Screen 4G LTE Phone Black $143.99
    Cubot H1 MT6735P Quad Core 1.0GHz Android 5.1 Smartphone 2GB Ram 16GB Rom 5.5 Inch HD Screen 4G LTE Phone Golden $145.99
    Cubot H1 MT6735P Quad Core 1.0GHz Android 5.1 Smartphone 2GB Ram 16GB Rom 5.5 Inch HD Screen 4G LTE Phone White $145.99
    The Cubot H1 has a rapid charging system to feed its large removable battery of 5200mAh capacity that is more than sufficient to run its 2.5D 5.5 inch HD IPS 1280 x 720 pixels screen of resolution. The device also runs Android 5.1 Lollipop O.S and Bluetooth 4.0, and the powerful 64 bit Mediatek MTK6735P Quad-core ARM Cortex-A753 processor at 1.0 Ghz working over 2 GB of RAM will make any processing task simple and easy. The Cubot H1 has a storage capacity of 16GB that is expandable up to 32 GB via Micro SD card. It has two slots for SIM, one for regular and one for Micro SIM. The IR port in the phone also enables you to control, a television, air conditioner or other device supporting IR control. The rear camera is of 13MP with an image resolution of 4128 x 3096 pixels operating over f / 2.0 aperture, and CMOS sensor. And the front camera is 8MP and has an image resolution of 3264 x 2448 pixels and is composed of four lens elements. The phone size is 154.5 mm x 76.6 mm x 9.2 mm and weighs 168 grams. Its body is made of metal and plastic, and like mentioned above, the phone has black, white and champagne color options.
    cubot-h1-golden-1.jpgcubot-h1-white-1.jpgcubot-h1-black.jpgcubot-h1-black-2.jpgcubot-h1-black_4_.jpgcubot-h1-black_2_.jpgcubot-h1-black_5_.jpgcubot-h1-black_3_.jpgcubot-h1-black_7_.jpgcubot-h1-black_1_.jpgcubot-h1-black_6_.jpgcubot-h1-black_8_.jpg
    Specifications of Cubot H1
    Display : 5.5 inch IPS HD 2.5D 1280 x 720 pixel resolution with 267 ppi.
    SoC : Mediatek MTK6735P.
    CPU : Quad core ARM Cortex-A753 1.0 GHz 64-bit.
    GPU ARM Mali T720 MP2 at 400 MHz.
    Battery : Removable 5200mAh Li Polymer. Fast charge.
    RAM : 2GB LPDDR3.
    ROM : 16 GB expandable to 32 GB via micro SD.
    Cameras : Rear 13 megapixel and front 8 megapixel.
    Operating system : Android 5.1 Lollipop.
    SIM : Dual SIM, SIM and Micro SIM.
    Wi-Fi : 802.11b / g / n.
    Networks:
    GSM 850/900/1800/1900 MHz.
    WCDMA 900/2100 MHz.
    LTE 800/1800/2100/2600 MHz.
    GPRS, EDGE, HSPA +, UMTS and LTE Cat 4.
    Video formats : AVI, DivX, 3GP, MP $, MKV, WMV, Xvid and Web M.
    Audio formats : MP3, MIDI, M4A, OGG, WMA, WAV, FLAC, AAC, AMR and eAAC +.
    Bluetooth: Version 4.0 LE (Low Energy).
    Sensors: Accelerometer, proximity, compass and light.
    Infrared port.
    Headphone output: 3.5 mm Jack.
    USB : USB 2.0 Micro. Loading and OTG (On The Go).
    Materials : Metal and plastic.
    Dimensions : 154.5 mm x 76.6 mm x 9.2 mm.
    Weight : 168 grams.
    Colors: Black, white and champagne.
    If you are looking for a mobile phone which can provide great battery backup and performance, then Cubot H1 is a good choice.
    Hands on Cubot H1 specs, camera, game, antutu video from 1949deal
    [video=youtube]https://www.youtube.com/watch?v=A79-LzTbxu8[/video]
