A teardown of the Huawei Honor 6
Home Forums Android Hardware News on Android Hardware A teardown of the Huawei Honor 6
This topic contains 0 replies, has 1 voice, and was last updated by  imported_umit 2 years, 6 months ago.
  • #6333
    The Honor 6 uses the Kiring 920 which is made up of four A15 cores and four A7 cores. Its GPU is the Mali-T628. This phone also sports a 5-inch 1080p touch screen, with 3GB RAM and 16/32GB internal memory space. It also has a 5mp/13mp dual-camera. Its operating system is the Android 4.4.2 and is powered. Lastly, it’s powered by a 3100 mAh battery.
    s_1d6b20a8d3e446469e96f6873322b923
    Double-glass + double-reinforcement —- The Huawei Honor 6 disasembled
    s_38708fcf3fd846d793a6af1f288afb83_meitu_2
    So How’s the first cell phone to use the Kirin 920? Let’s check it out!
    s_48c2923598184144844bb414bbb8127e_meitu_3
    Both sides are made of glass which is covered with a thermal pad.
    s_500d39f093314470be751587902de83a
    The glass in the back is quite strong.
    s_3b70086409d5461f894221c47ca58b8e_meitu_5
    The motherboard is covered with a metallic shielding case, which, other than protecting the motherboard, makes the phone sturdier.
    s_8c91743795e74b789f53f50ad1933373
    Inside the phone, it sues an L-type motherboard. More chips needed and the phone needs to be more compact to increase stability.
    s_882c565daade4a02a388426e352436e0_meitu_7
    Top: dual flashlight
    Bottom: Speaker
    s_ca7a98b8d3334ddf9bce18867cc6326c
    Metal shielding case
    s_5e8084c7342047aabd3f23433ccacfe0_meitu_8
    In addition to the shielding case, the phone is reinforced by a duralium case as well. According to the date it was produced, this was determined in June.
    s_c6028415e93049d5b3e8883c9b868be3
    The Honor 6 uses a 3100mAh battery, making it one of the few cell phones with a 5-inch 1080p screen to use a battery with more than 3000mAh.
    s_fb91065c5fa44a5d9ef1633a047deaec_meitu_9
    Left: Vibrator
    Middle: speaker
    Right: earphone port
    s_5cc0fdf3771d4aaa968e5da72f3f4924_meitu_10
    It sports a 5mp/13mp Sony dual-camera and supports automatic beautification function.
    s_ee46835076e14e73b3a24bd67db12b5c_meitu_11
    Middle: Noise-cancelling microphone
    Right: Infrared transmitter
    s_946bfa5d14a44383959e173a50b9ef77_meitu_12
    A close-up of the Skyworks 77590-11 GSM/GPRS/EDGE chipset.
    s_37a9b919dd87492bb2ab3b7263557b57_meitu_13
    Close-up of the HiSi Hi6401 audio chip. Both the Huawei P6 and P7 use it.
    s_273aaed7d2ef4b50b52062056e9f7812_meitu_14
    Kirin 920 + Samsung’s 3GB RAM chip
    s_261ce386f8aa4675b2884dd0184a0f7c_meitu_15
    Samsung’s 16GB internal memory storage chip
    s_64dcf5fc514b4562840280c4cc776bd6_meitu_16
    The Hi6561 power management chip.
    s_70723448f2214c25963dac8331939379
    MicroUSB port, recharging port, and speaker phone
    s_5b193801df664f21ade71af635ec01f4
    WiFi and Blu Ray chips
    s_8f8bb3e2bbc84728b62a86df551f7837_meitu_19
    s_43ac8f2de8a64179a9917a93ff3d5749s_26824fb7dfa642faa64894f49f6b1116_meitu_21
    s_c3a23a6b42df4f43a55da5c6bf8407e6
    Unlike other cell phones:
    1. The Honor 6 guarantees 4G signal overflow, and uses a 3000mAh battery.
    2. The Honor 6 uses the new Kirin 920 processor.
