【Pre-Orders】Three Types of BlitzWolf USB Reversible Data Cable with discount
Home Forums Android Hardware Where to Buy Banggood 【Pre-Orders】Three Types of BlitzWolf USB Reversible Data Cable with discount
This topic contains 1 reply, has 1 voice, and was last updated by  banggood 1 year, 1 month ago.
  • #9774
    banggood
    Hi, Droidchina friends,
    Three kinds of BlitzWolf USB Data Cable can be pre-ordered from now on.
    [size=large]BlitzWolf™ 3A USB Type-C PVC Reversible Data Cable 3.33ft/1m USB 3.0 A Male to USB 3.1 Type-C Male for Nexus 5X 6P OnePlus 2 Nokia N1 Xiaomi 4C Zuk Z1[/size]
    Preorder Discount Before 1000th Orders
    $3.59 0-50th orders
    $3.99 51-200th orders
    $4.59 201-500th orders
    $4.99 501-1000th orders
    Normal price: $5.99
    Product information:
    Brand: BlitzWolf™
    Model: BW-TC1
    Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible PVC Jacket
    Plug: Standard USB3.0 A Male to Double-Sided USB3.1 Type-C Male, Nickel-plated Reversible Connector Head
    Wire Core: 32 AWG(Data)*3 + 24 AWG(Power)
    Output: 5V/9V/12V, up to 3A
    Data Sync Speed: Up to 5Gbps
    Length: 1m/3.33ft
    OD: 4.5mm
    Color: Black
    Product description:
    Double-Sided Plug Design: The cable uses a double-sided USB3.1 USB Type-C male reversible plug allowing you to plug it in
    without needing to recognize the positive or negative, just like the apple lightning cable.
    URL: BlitzWolf™ PVC 3.0 Type-C
    [size=large]BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 3.33ft/1m USB 2.0 A Male to USB 3.1 Type-C Male for Nexus 5X 6P OnePlus 2 Nokia N1 Xiaomi 4C Zuk Z1[/size]
    $3.99 0-50th orders
    $4.59 51-200th orders
    $4.99 201-500th orders
    $5.59 501-1000th orders
    Normal price: $6.99
    Brand: BlitzWolf™
    Model: BW-TC2
    Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible Braided Jacket
    Plug: Standard USB2.0 A Male to Double-Sided USB3.1 Type-C Male, Nickel-plated Reversible Connector Heads
    Wire Core: 30 AWG(Data) + 24 AWG(Power)
    Output: 5V/9V/12V, up to 2.4A
    Data Sync Speed: Up to 480Mbps
    Length: 1m/3.33ft
    OD: 2.8mm
    Color: Black Cable & Gray Metal Plug, Red Cable & Black Metal Plug
    URL: BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 3.33ft/1m
    [size=large]BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 6.56ft/2m USB 2.0 A Male to USB 3.1 Type-C Male for Nexus 5X 6P OnePlus 2 Nokia N1 Xiaomi 4C Zuk Z1[/size]
    $4.99 0-50th orders
    $5.59 51-200th orders
    $5.99 201-500th orders
    $6.59 501-1000th orders
    Normal price: $7.99
    Brand: BlitzWolf™
    Model: BW-TC2L
    Wire Core: 28 AWG(Data) + 22 AWG(Power)
    Length: 6.56ft/2m
    OD: 3.5mm
    URL: BlitzWolf™ 2.4A USB Type-C Reversible Braided Data Cable 6.56ft/2m
    Have fun,
    Doris Lee
    #18552
    banggood
    Hi, DroidChina friends,
    This cable is designed to be compatible with all micro USB devices; however, some unbranded devices use substandard
    micro USB ports that might damage the cables connector, in these cases we recommend you use the original charging cable.
    The key to the dual sided operation is the inner core. It is made of a thin but tough, flexible and guidance plastic that ensures a
    tight reversible connection to your device. :blush::blush:
    It’s available on Banggood now.
    [size=large]50% off BlitzWolf® 2.1A Reversible Micro USB Cable Double Sided USB A Male to Double Sided Micro B 3.3ft/1m for QC2.0[/size]
    Brand: BlitzWolf®
    Model: BW-DC1
    Material: Protective Tinned Copper Mesh + Aluminum Foil Shielding + Environmental Flexible TPE Jacket
    Plug: Double-Sided USB A Male to Double-Sided Micro B, Gold-plated Reversible Connector Heads
    Output: 5V/9V/12V, up to 2.1A
    Length: 1m/3.33ft
    Color: Black, White
    The cable uses a double-sided USB A male plug and a double-sided micro B reversible plug allowing you to plug it
    in without needing to recognize the positive or negative, just like the apple lightning cable.
    Gold-plated reversible connector heads and 3.33ft/1m flexible TPE wire sheath with 24AWG power and 30AWG data tinned
    copper wire cores, it can be bent over 3000 times and with no damage or change in performance.
    Supports 5V/9V/12V fast charging at up to 2.1A current, compatible with Qualcomm QC2.0, MTK Pump Express Plus and other fast
    charging technology.
    Compatible with most of micro USB digital devices like smartphones, tablets, MP3 players, PDAs, digital cameras/camcorders,
    hard drives, e-readers, power banks, portable game players etc.
    More details, click here.
    Have fun,
    Doris Lee
